Urgent - replace physical sim with esim
Olwyn1995
I need to replace my physical sim with an esim Urgently
i have lost my physical SIM card and need an eSIM replacement with the same phone number urgently so that I can access my online banking
8 REPLIES 8
@Olwyn1995
the International text is to receive text when you are in Canada, ie, you can receive text from your overseas friends.  It is not to send text or receive text when you are not in Canada
Olwyn1995
Thank you! Last question I promise - I can see international minutes on plans offered by public mobile, is it possible to receive texts internationally with public mobile?
@Olwyn1995 wrote:
That worked thank you so much - will it have the same phone number?
 @Olwyn1995
yes, you will get to keep the same number as you are logged in with the same email address
Olwyn1995
@Olwyn1995
Just click on Resend Code or Didn’t Receive Code and have the 2FA code sent to your email.
Olwyn1995
Thank you for the help but I can’t login to the app as I have lost the SIM card and therefore don’t have access to the phone number and you need to be able to receive a text to login to the app.
@Olwyn1995
you can do so if you can login using email or voicemail to receive 2FA
first, download the app on your new phone and login.  If you have problem with receiving 2FA code, click "Didn't Receive code" or "Resend code" and choose either Send email or Send voice message
Once logged in, Click Account from the bottom, then click Purchase SIM Card and select eSIM
Once it confirms your phone is eSIM compatible, click Pay $  and Install
If you cannot login the app to buy eSIM, then the fastest way is to go to a Telus/Koodo/Mobile Klink store and buy a Public Mobile sim card.  Then message PM CS agent and ask them to update the sim card number.  Private message CS Agent at:
@Olwyn1995
To replace with eSIM on the same account. Just login to your account on the PM app and purchase an eSIM under Accounts then Purchase SIM Card and there is an option for eSIM.
