01-24-2024
10:28 AM
01-24-2024
12:18 PM
computergeek541
Hello,
I like the $24.00 4GB plan under 4G, but I am currently registered for the 3G 1GB data plan for $24.00. How can I upgrade to that offer from my existing plan?
Thanks!
Emal
01-24-2024 10:33 AM
This plan is for new customers activations.
You can try to contact customer service agent to see whether they can change the plan. No guarantees though. There is a better chance if you were on the $15 plan and wanted to "upgrade", then sometimes CSA would be receptive to changing plans.
Send a private message to CSA through the following link :
