10-23-2020 07:48 PM - edited 01-05-2022 05:19 PM
HI there I"m trying to update my plan before expire date but its not working.
I ran out of data and my plan is expiring in a week.
Thanks
10-23-2020 07:52 PM
@maan wrote:HI there I"m trying to update my plan before expire date but its not working.
Thanks
If you are trying to renew the same plan immediately you need to contact a moderator. You can always buy a data add on too.
Here’s how to contact the Moderator Team (Public Mobile representative) for assistance:
10-23-2020 07:51 PM
You can't update or renew the same plan earlier by yourself. You will need to contact moderator to renew same plan earlier.
Another option is to switch to another different larger data plan immediately via self service account. Public mobile does not pro-rate plans and you will lose whatever is remaining in your existing plan.
To contact moderator via 2 methods:
Click on the question mark on the right lower corner of website to start ticketing process to contact moderator. Type: Contact moderator. Follow the prompts to submit ticket.
or
2 Send a private message to moderator through the following link :
