Updated app
Kay_891
Great job. Before the update, it was slow. Now, it isn't usable. I'm not surprised.
How do I turn off voice mail. While spam messages don't ring they still can access my voice mail and they dont say anything. They fill my voice mail every day. What's the point having it
1 REPLY 1
LitlLdy
@Kay_891 , I had to uninstall the app then install it again for it to work.
You can set your voicemail to extended absence greeting & set it so callers can’t leave voicemails (that’s what I use).
  • Dial into your voicemail and log in with your PIN.
  • In the main menu, press 3 (manage greetings),
  • then 4 (manage extended absence greeting),
  • then 2 (record a new extended absence greeeting) and record a message that indicates to your caller you are not accepting messages.
  • Then press 4 to turn on extended absence
  • Finally, press 5 to dissallow anyone to leave you a message.  Problem solved!
