Updated Oneplus 3t Can only Get H+ Data After Update
Ozwinjer
Oneplus pushed their latest update to my phone today and I updated it. Now my phone will only connect to H+ whereas before it had no problems with 4g+ etc. (I have a 4g/LTE plan)
I tried deleting all my APNs and entering them manually but im stock at H+. Any ideas? Thanks!
Android 8.0.0
Android Security Patch Level: Sep 1, 2017
Oxygen 5.0
srlawren
@Ozwinjer cool, I'll try it out soon 🙂
Ozwinjer
No noticeable difference or bugs other than the Sim issue noted above.
I am not a power user however so your expectations may be different from mine 😁
srlawren
@Ozwinjer how's Oreo on the 3T so far?  I got the notification on my OP3 a few days ago but was travelling and didn't install it at the time.  Is it stable so far?  How's the battery life compared to 4.5.1?
Ozwinjer
Yessir I did.
However, I solved the problem. Although I had a second sim in my phone (it was disabled) I removed the second sim in my card and got 4g.i then reinserted the second and everything worked as it should. Weird!
Thank you
CalvinW
Have you tried restarting the phone? Toggling on and off airplane mode to allow the phone to connect again?
