Update payment method for my dad's plan
Jey75
Hi, adding to my last message:
I would also like to pay the amount overdue on my dad's accoun. Tried to do it over the phone but we never set up a PIN.
Thanks!
@BKNS27 wrote:
@Jey75
You can reset the PIN but you need his login ID and password.
https://myaccount.publicmobile.ca/en/account/reset/pin
The member Jey75 has already stated that the account cannot be logged into.  The above will not work.
@Jey75
@Jey75 use the voucher method of you need to pay urgently
For login, ask PM CS agent for help
Private message CS Agent at:        https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
Jey75
Thanks but the trouble is i cant login to my dad's account due to whatever reason and the double verification code going to his phone makes it harder. I think I've accidently deleted his number for the verification code whole I was trying to add my number to it. This no human customer service is making it very difficult.
@Jey75
Pay  by login to My Account or  PM app
If not, another quick way is to get a voucher from SDM/Rexall/Loblaws/CanTire and then use *611 to load the voucher (no account pin required).
Or you can also buy a voucher online with a fees via muskbird.com/ding.com/recharge.com and then load the voucher using *611.
