Upcoming Sub
Yourbakerman
How do I find out the data that is in my upcoming subscription? It says 5g but not the data I will be reciving.
Yourbakerman
That worked ty
The subscription should tell you what you get with it. If not, you can log in online and check there.
Jedi1
Try looking at the payment screen.  It should show you the expected renewal payment and will also give more detail on the expected plan.
Yourbakerman
I did that first and it says the Cost and 5G but not the data
Yourbakerman
I did that first abd it says the amount and 5G but not the data
Chalupa_Batman
Best way to view this is to download the app on your phone. Log in, then go to Subscriptions and you'll be able to see the upcoming change there. It will show the plan and details you changed it to.
