Unlimited taking and texting
m87ie
cCould you please let me know regarding the following:
unlimited talk Canada wide
unlimited text international
Is it for the local city or could be used from anywhere in Canada
thanks and tegards
pakmode
As others have mentioned above it's easy and straightforward to use. Plus, you never have to worry about extra billing charges as it is a prepaid service and you cannot be billed for extra.
cmatassa
Both the Canada-wide calling and International texting will work from anywhere in Canada where you have reception.
NDesai
Yes, Talk (Canada-wide), Text and Data will work from anywhere in Canada.
ShawnC13
thanks and tegards
Anywhere in Canada that has a Telus signal you can use that plan  https://www.telus.com/en/bc/mobility/network/coverage-map
