06-24-2018 06:10 PM - edited 01-04-2022 06:17 PM
In the past month or so i've been experiencing issues with my phone with Public Mobile network. Signal is weak in my office as well my home, they were used to be full bar but now mostly 1 bar. And lots of time I have to restart my phone so that i can make a call or otherwise no call can be dial out or dial in. Can someone look into my account to see what's wrong? It was working perfectly since I moved to PM till a month's ago. Thanks.
07-03-2018 10:36 AM
Tried this over the weekend, and turns out it's the iphone 6 issue. Network is fine. Thanks everyone above for the help!
06-24-2018 08:29 PM
James_c, can you please try putting the iPhone's SIM card into the Pixel 2 phone (making sure to power them both OFF first), and let us know if the signal strength and behaviour are the same as before? Thanks.
06-24-2018 08:10 PM
I would point the finger at the phone when signal issues are persistent. If it is a network problem, everyone in the affected area would experience the issue and it would be readily reported. Account issues generally result in functions that just stop working. Electronics can spuriously fail. I would try a different phone or troubleshoot phone related solutions.
06-24-2018 06:33 PM
@james_c, can you swap SIMS, and see what happens?
06-24-2018 06:29 PM
I sent a private msg to the mod regarding the issue, hopefully they will come back with somthing. The phone is Iphone6, has been working fine, no drop no water no hammer etc, i have another pixel2 which was transfered to koodo, working fine in the same location tho.
06-24-2018 06:23 PM
@james_c Problem is likely not due to an account issue and so the first reply is clearly not a solution unless mod already got back to you with a solution to your problem.
06-24-2018 06:18 PM
@james_c Try the sim in any other unlocked phone and see if you get the signal you used to get before. Check your network settings and make sure LTE is selected. Unless there is an outage on nearby towers, signal should not drop at the same location.
06-24-2018 06:16 PM
@james_c, Any chance the problem could be with the phone? Was it dropped, or otherwise damaged around the time the problem started? Got wet?
Any chance you have access to another (PM compatible) phone that you could try with your SIM card?
BTW, most of the people on this forum (other than those with MOD next to their name) are Public Mobile customers like you. We can't actually check anything on the network side. however, if you DO need/want to have someone at PM check into this, you would need to send a private message to the moderator team.
Click here to send the moderator team a private message. Their hours are: Mon-Fri 9AM-9PM(EST) & Sat/Sun 9AM-7:30PM(EST)
You can find information regarding the moderator team by following this link.
Include your phone# (or account#) and account PIN (if known) to avoid back/forth identity check.
06-24-2018 06:14 PM - edited 06-24-2018 07:14 PM
Only the Mod Team can look into your account, here's how to contact them.
EDIT: Fixed my wonky macro. Sorry.
Need assistance with your account, activation, or service?
In your private message please include the following:
Don't know your PIN? Provide any three of the following:
When will they get back to you?:
