05-21-2023 07:47 PM
Can I please have someone to take a look at my number?
I checked the account page, paid on time and the text service is working fine.
I tried calling *611 according to the voice message, it automatically cancelled after a moment.
The error code is 8uv1.
05-21-2023 08:36 PM
Problem solved.
Thanks you sir!
I played with it for a while and turns out one of the sim card slot is broken.
05-21-2023 07:52 PM
@ZJxyo can you check My Account again using Incognito mode and confirm again if status is active . This assure you are checking the latest status and not cached info
and try if any of these works
