06-21-2025 02:46 PM - edited 06-21-2025 02:49 PM
My iPhone 11 pro Max and Public Mobile App is updated to latest software. When I select eSIM to purchase through the App, it shows $5 but the "Place Order" button is greyed and does not do anything. I verified credit card info saved and is all correct. Any reason or solution?
06-21-2025 02:58 PM
Thank you..that worked and got the esim installed and activated 🙂
06-21-2025 02:48 PM
Uninstall and reinstall and try again
