01-02-2023 02:02 PM
I have 2 accounts and 2 different phone numbers. One account I can log in with no problems. The other account, that I need to update payment info, is not letting me log on. What could be the problem? Seems the account is still active as I can receive text messages.
My Account
01-03-2023 01:08 AM
Did you activate online or in store? Did you use the same email address for both accounts? If so you will not be able to log into your other account because one account's username and password overrides the other. You will need to contact customer support with a separate email address for your other account.
01-02-2023 02:07 PM - edited 01-02-2023 02:09 PM
You might want to reach out to a Customer Support Agent and have them look into your account.
Use the Chat Bot Simon to get a service ticket started first.
The link is at the bottom of this page.
01-02-2023 02:06 PM - edited 01-02-2023 02:08 PM
What kind of error messaging are you getting, @Cucucita ?
Recommend using a COMPLETELY different device and browser to access the other account.
What do you hear for a recorded message when you dial *611 from the device?
01-02-2023 02:06 PM
@Cucucita @You can also try and reset your password or get further help from agent
Getting help from agent , through automation
- Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to our Agents. Click here to get started.
Or get direct help from a agent right here in the community ( my preferred choice )
- Alternatively, you can send a private message to our Agents by clicking here. You’ll need to be logged in to your Community account for the link to work
01-02-2023 02:06 PM
I have three
foe my fil I have to use the computer only won’t let me on my iPad even Incognito 🥸
01-02-2023 02:04 PM
Yes, tried that already
01-02-2023 02:04 PM
@Cucucita @Try logging in again in incognito / private mode or even with a different device there are cache issues
01-02-2023 02:03 PM
Try logging into your account using a browser in incognito or private mode instead.
