01-02-2023 10:33 AM
is Motorola Edge 2022 phone compatible with public mobile plan?
01-03-2023 01:28 AM
@BKNS27 wrote:If it is purchased in North America it should be no problem using PM.
There are many phones that can be purcahsed in North Amerca that don't work at Public Mobile that were imported from various places around the globe, although some of them will work. However, Motorola devices sold through official authorized channels will be fine.
01-02-2023 12:41 PM
01-02-2023 10:38 AM - edited 01-02-2023 10:39 AM
YES, your Edge 2022 will work on PM network It has the compatible bands to be used on PM network
this are the bands on your phone, BOLD are the compatible ones.
HSDPA 850 / 900 / 1900 / 2100
4G bands 1, 2, 3, 4, 5, 7, 8, 12, 13, 14, 20, 29, 30, 40, 41, 48, 66
and fyi, these are the bands PM network needs
01-02-2023 10:35 AM
@atilara @Yes it is no worries
01-02-2023 10:35 AM - edited 01-02-2023 10:37 AM
Yes it is @atilara
It has necessary specs to PM's network for calling, texting, and data.
Here's it's specs:
https://www.google.com/amp/s/m.gsmarena.com/motorola_edge_(2022)-ampp-11777.php
01-02-2023 10:35 AM
It should be if it is 2022 model.
https://www.publicmobile.ca/en/bc/get-help/articles/check-your-phones-compatibility
Public Mobile uses the following frequency bands:
4G LTE and LTE Advanced: 700 MHz, 850 MHz (band 5), 1900 MHz (band 2) and 2100 MHz downlink and 1700 MHz uplink (AWS).
3G/HSPA: 850 MHz, 1900 MHz (UMTS).
As long as phone supports these frequencies, it should work.
