Unable to change Plan
06-15-2020 05:06 PM - edited 01-05-2022 11:42 AM
06-15-2020 08:22 PM
Best bet is to clear cache and log in via an incognito mode.
Or, like suggested, wait an hour or two and revisit the site. Sometimes the website has a small hiccup.
06-15-2020 07:52 PM
This has happened to.me before I think sometimes they are doing maintenance or the site is just not functioning properly. I ended up coming back after a few hours and accessing it then.
You can try using your incognito browser. Or clear your cache and history, although from experience that dis not help, waiting a little did.
I have also in the past sent a quick private message to the mods explained my self-serve is down, they contacted the tech team and got it running.
For future use here is the private message link:
06-15-2020 05:42 PM
@NTS1122 Also, can try to clear cache and cookies.
06-15-2020 05:40 PM
06-15-2020 05:32 PM - edited 06-15-2020 05:33 PM
@NTS1122 try using your browser in incognito or private mode
06-15-2020 05:09 PM - edited 06-15-2020 05:10 PM
@NTS1122 hi in your self serve where it says change plans click on it you can change any plan there
