Uber 3g or lte ?
08-08-2018 11:37 PM - edited 01-05-2022 05:19 AM
Thinking of doing uber
Anyone know if i went with a 3g plan would that be good for doing uber driver ?
Or sould i go with Lte. Its just 3g plans are cheaper
Thanks
Service
08-09-2018 02:21 AM
In theory, yes it wouldn't take long to go through 4.5 GB, but the data tap isn't always turned on to full capacity every second of use. I use Waze a lot, and stream music while driving about 2-3 hours a day, and still never go over my data cap with PM. Cut out the music streaming, and you could probaby use GPS and the uber client for a solid 8 hours a day.
08-09-2018 02:17 AM
The weakest link in the chain so to speak is the amount of usage. If "3G speed" is insufficient, then the 4.5GB is even more defiicient. It takes less than 10 minutes at 3mbit/s each day to consume the entire 4.5GB data allotment. This puts into perspective how much higher speed really means.
08-09-2018 12:49 AM
3G it up. It should handle everything you need.
08-09-2018 12:33 AM
@Salvo wrote:Thinking of doing uber
Thanks
The PM 3G is throttled LTE so you get the latency of LTE just at a throttled speed.
08-09-2018 12:05 AM
3G should work. I use waze with Public Mobile at the same time I stream with Spotify, and it all works with no issues. You could always try it out and if you need faster speeds, switch later on.
08-08-2018 11:52 PM
Thanks
I can't see providing Uber service requiring a super high speed internet connection. Reliability is proabably more important than anything else. I would imagine that to provide Uber service, you would proably need to use your internet connection to confirm bookings, contact the customer, and to use gps and mapping.
