USA Addon Text messages
02-13-2020 10:16 PM - edited 01-05-2022 09:30 AM
02-13-2020 11:20 PM
You should be able to receive messages, that's apparently positive bug, so you shouldn't miss any of them. If you install TextNow you will be able to respond to urgent ones. For the talk if you pick Canadian number, you can forward to it for free, that way you wouldn't miss any calls with local data or wifi and would have access to it voicemail.
If I was frequently in USA I would definitely consider getting that sim, they are on Sprint and att network I believe, then you don't have to chase WiFi either
BTW if you'd like to check your voicemail now, call yourself (hangouts or TextNow) and press start during the getting, if you remember your voicemail password. If you don't you can reset it in your selfserve, it will be your phone number.
02-13-2020 11:05 PM
Catching up with this thread...so you had roaming texting. It has recently changed to being 10 - 24 hour periods. Then there's a re-buy delay. I theorize that that roaming texting will re-appear for you at midnight ET.
Or you ask the moderators to re-up it. Deposit sufficient funds to avoid more delays.
The regulars here would be interested to know if you are able to see that add-on again at midnight ET if you don't ask the mods.
02-13-2020 10:58 PM
Where we are wifi is spotty to say the least so I have to make a special trip (like now) to the internet cafe to log in to get answers from PM
02-13-2020 10:56 PM
I go back and forth to BC, I saw a $60 plan back in October which included the USA but then they abruptly stopped it! I need my current number for my business calls and texts and usally end up buying phone and text but as I will be back in Canada on Monday I decided I texting could do and I'll pick up all the phone messages when I hit Vancouve between flight - but here I at the mercy of PM as to when they will resolve the problems.
02-13-2020 10:55 PM
You also get to pick Canadian or USA number.
Data rates are reasonable too, unlimited is 40
02-13-2020 10:52 PM
@Bj2001 download the Texnow app and use it over WiFi in the meantime to text and call in The US for free.
02-13-2020 10:52 PM
Sorry about that
How long are you staying there?
If you are on expended trip you could look into TextNow sim card. Talk and text are free no roaming charges coast to coast, only upgrade if you need data. Sim costs 10usd and you can keep it forever
02-13-2020 10:49 PM
yup messaged them twice but like all the problems I have with PM while in the USA I am at their mercy as to when they will respond ... thanks for your time
02-13-2020 10:46 PM
To bypass Simon click onhttps://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
Good luck
02-13-2020 10:45 PM
yup bought them 11 days ago and got a message yesterday on 611 to say go to PM and add it on as it has expired!
02-13-2020 10:45 PM
@Bj2001 wrote:tried all that but Simon sends me to the 404 page with whoops we are too busy to help youi!
Try direct
02-13-2020 10:43 PM
@Bj2001 wrote:As I said I can't take a screen shot but here is what will copy and there is nothing under the TEXT option - I'm not lying and hate this waste of time dealing with PM
Talk6TextData7US Roaming Bundle6
200 min US and Canada Long Distance - $8.00$8.00 400 min Intl Long Distance (Incl Canada & US) - $15.00$15.00 500 min Canada-Wide Long Distance - $5.00$5.00
1GB Add-on - $30.00$30.00 200MB Add-on - $10.00$10.00 US Roaming - 1 GB Data (10-day) - $20.00$20.00 US Roaming - 250 MB Data (10-day) - $10.00$10.00 US Roaming - 500 MB Data (10-day) - $15.00$15.00
US Roaming - Talk Text (10-day) - $15.00$15.00 US Roaming - Talk Text 250 Data (10-day) - $20.00$20.00
Add-Ons$0 $ plus applicable taxes
Did you already buy them?
They are not available once you purchase them
02-13-2020 10:43 PM
02-13-2020 10:42 PM
200 min US and Canada Long Distance - $8.00 $8.00 |
400 min Intl Long Distance (Incl Canada & US) - $15.00 $15.00 |
500 min Canada-Wide Long Distance - $5.00 $5.00 |
1GB Add-on - $30.00 $30.00 |
200MB Add-on - $10.00 $10.00 |
US Roaming - 1 GB Data (10-day) - $20.00 $20.00 |
US Roaming - 250 MB Data (10-day) - $10.00 $10.00 |
US Roaming - 500 MB Data (10-day) - $15.00 $15.00 |
US Roaming - Talk Text (10-day) - $15.00 $15.00 |
US Roaming - Talk Text 250 Data (10-day) - $20.00 $20.00 |
Add-Ons$0 | $ | plus applicable taxes |
02-13-2020 10:41 PM - edited 02-13-2020 10:42 PM
@Bj2001 wrote:when I try to go to click on the button for the chat help after it posts "Looks like we'll need the help of our Moderator Team to take care of this issue" it takes me to a 404 page wiith
"Whoops! Looks like we were too busy thinking about you. Go to homepage.404"
Try
02-13-2020 10:38 PM
02-13-2020 10:38 PM - edited 02-13-2020 10:40 PM
Did you already buy?
If you made a purchase you won't be able to buy another one until they expire. Unfortunately they can't be just stacked one after the other and there is a bug that makes you wait 24 hours between your add-on expiring and it appearing available for purchase
02-13-2020 10:37 PM - edited 02-13-2020 10:40 PM
@Bj2001 Use 611 from your phone to add it. Here's a link on how to use it. https://productioncommunity.publicmobile.ca/t5/Self-Serve/611-IVR-Menu-System/m-p/289352/highlight/t...
You can then contact a moderator and explain your situation. Click on the green questionmark in the white circle at the bottom right of your screen . This connects to the autobot Simon. Type moderator and follow the prompts to get to one (CLICK on account specific question and human and submit a ticket)
Or contact them directly by private message here https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
02-13-2020 10:36 PM - edited 02-13-2020 10:41 PM
You are right and there they are under texting and the other one under talking.
Just strange way to sort them
02-13-2020 10:35 PM
02-13-2020 10:34 PM
no it is blank, hence its very frustrating
02-13-2020 10:32 PM
@Bj2001 wrote:I am on a public computer so can't take screen shots to show this howver If you look at the webiste page you will see USA Addon advertizing $8 for 10 days
https://www.publicmobile.ca/en/on/plans
but like you shot it's not showing up even though it is supposed to be an option for us to add on....extremely frustrating
Is it over on the left side of the page like I'm showing above?
02-13-2020 10:27 PM
02-13-2020 10:21 PM
I obit remember 200 long distance minutes that is not roaming package a all
I don't have anything like that either
