09-25-2024 04:46 PM
On Sep 21 2024, I purchased USA top up plan but my phone did not work in USA.
09-25-2024 07:41 PM
@rajpatel, no, you do not need to buy data as well to have talk and text work. But if your phone is not on the PM white list for VoLTE devices then you likely would not have talk/voice work but at a minimum you should have been able to send and receive text messages with the US talk and text add-on. With a non-VoLTE support phone you would need to manually connect to T-Mobile 2G network for voice which is getting harder to find in the U.S. but not impossible
09-25-2024 05:04 PM
Samsung A15 is not on the PM's VoLTE whitelist, you can try to change the network mode to 2G and connect only to T-Mobile and hope if t works
if not, you can ask PM for refund.
For the calls, there is workaround. You can download and use voip app like Textnow to make calls using wifi
09-25-2024 05:03 PM
Is it possible you purchased a Long Distance plan to call to the USA *from Canada,* not a Roaming US plan to call *while in the US*?
09-25-2024 05:01 PM
I have Samsung A15 phone.
09-25-2024 05:00 PM
US talk, you have to tell us what phone you have.
depends on the phone, some phones need to use T-Mobile 2G network to get connected with calls. But the network is old and it is hard to get the network
but if you have an iPhone or other VoLTE whitelisted phone by PM, you can use the VoLTE to make calls
09-25-2024 04:58 PM
I purchased USA talk and test only. Do I have to purchase data also for phone to work in USA.
09-25-2024 04:56 PM
you tried all three networks , connect manually?
what phone you have?
09-25-2024 04:55 PM
Roaming was turned ON.
09-25-2024 04:54 PM
Thanks for your reply. I did manually change different service provide and it still not work.
09-25-2024 04:49 PM
hi @rajpatel
make sure you have roaming mobile data enabled on your phone
and make sure you see the phone connected to T-Mobile or AT&T or Verizon. Change network mode to 4G or LTE for easier connection. For the network , you can also try to connect each of them manually and one of them would work
09-25-2024 04:48 PM
what phone do you have? i think you need to manually connect to AT&T or T-Mobile or Verizon to make it work. Go to Connection screen, change automatic to manual and try all 3 networks, it should work
09-25-2024 04:48 PM
@rajpatel
Did you have turn on roaming while in the US? It needs to be on to work.
