US rooming
11-28-2020 11:28 AM - edited 01-05-2022 04:16 PM
11-28-2020 02:44 PM
@Anonymous wrote:@esjliv : And ALSO the 1st column "Talk". 🙂
ah ha @Anonymous - yes! 🙂
I updated with current info. Thanks. 😉
11-28-2020 12:20 PM - edited 11-28-2020 12:21 PM
@AyadDayni wrote:What is the rooming plan in USA
Once you leave Canada, your Public Mobile accounted phone won't work unless
you can get a 10 Day US talk/text/data options that has been suggested already.
Public Mobile only has roaming options for US, no other countries...yet.
You can also use free voip apps like TextNow that allow calls / texts over wifi. I'm sure there's other apps but I've used TextNow and works good for me.
11-28-2020 12:04 PM
11-28-2020 11:36 AM - edited 11-28-2020 02:43 PM
11-28-2020 11:31 AM - edited 11-28-2020 11:33 AM
There are add-ons for talk or text or data or bundles thereof. They last for 10 days.
Buying add-ons is an un-intuitive 2 steps. Deposit money and then buy the add-on. The first step seems like you've bought the add-on.
You can't pre-buy. They're active as soon as you buy them.
Don't stack multiples of the same add-on function.
