US roaming
canavan
Hello,
Just quick question about roaming.
I would like to use call, text & 1GB of data.
If I buy $15 call & text bundle and $20 1GB data, does it work?
Thank you,
SD08
@mimmo wrote:
@Luddite  If i made a one time payment equal to the cost of the addon would i still need to purchase the addon twice?  If not, it might be an easier way to explain how to purchase addons
@Luddite wrote:
\b) you must by each add-on twice as first time around just adds to Available Funds,
I believe the double operation is because the first one is used to add funds.  If your account already has enough available funds, then you only need to do the purchase operation once.
mimmo
Luddite
@canavan wrote:
Hello,
Thank you,
Yes, that is my understanding. Just remember that:
a) the 10 days starts the moment you activate the add-on,
b) you must by each add-on twice as first time around just adds to Available Funds, and
c) you must wait until an add-on is used up, or expires, to add it again.
NDesai
Yes, it will work. Both will have 10 days of expiry.
Note: If you use all of the 1GB before 10 days, you will not be able to purchase it again before 10 days.
