08-27-2024
12:54 PM
08-27-2024
06:21 PM
computergeek541
looking at this plan. If I go to the USA, will I be charged any extra for roaming? Texting? I want to make sure that there will be no other charges when I get back from the USA
08-27-2024 01:42 PM
08-27-2024 01:30 PM
@CharlieQ All PM plans are prepaid. If you haven't bought a specific plan or roaming add-on in advance, it just doesn't work. You will never be charged any additional roaming fees.
08-27-2024 01:28 PM
@CharlieQ , be sure that you have a VoLTE capable phone when using the service in the US otherwise calling won't work. Note also that if you select this plan, chances are you will not be able to downgrade the plan later.
08-27-2024 12:55 PM
HI @CharlieQ
the idea of Canada-US plan is to allow you to use the same service in US like you are in Canada, all included in the plan. So, no extra charge when you go to US to use the service with this plan
