12-02-2019 09:16 PM - edited 01-05-2022 08:16 AM
hello everyone
when i cross the border to the US will i get a helpful text option to do an addon?
or is there a text code option to do the add ons rather than having to go online
also will i get a notification text when my addons are about to expire
and can we some how buy consecutively running add ons as i am heading for more than ten days - there was a post i saw that said you could contact a moderator but not sure if that meant that it was possible or not
please and thanks in advance
please and thanks everyone
12-04-2019 10:01 AM
definitely add a roaming plan to your account via the self serve page.
If it has a certain number of minutes or texts included in the add on it will notify you when you are going to run out
12-02-2019 10:14 PM - edited 12-02-2019 10:15 PM
@Angelfireheart It's best to add the U.S. roaming add-on the day that you are going on your tip before crossing the border. Your self serve account access requires an internet connection.
More than one of the same roaming add-on cannot be assigned to your account at the same time. Also, roaming add-ons start as soon as purchased, so don't buy them multiple days ahead of time.
