US roaming carrier
02-05-2019 06:55 PM - edited 01-05-2022 03:16 AM
What carrier do you switch to while in the US, and can you bundle the $20 talk, text and data plan with the 1GB data plan?
Joining Public
02-06-2019 11:49 AM
@mimmo wrote:I have done both. depending on time away (maximising usage)
in the usa you need to know your pin number and have a cc on file. then you can call 18554public
or you can do it on wifi via selfserve
@MJ23 if your trip is less than 10 days, I'd highly recommend buying it in advance. If you're going for a week, give youself a day on the end (buffer in case of cancelled flight, etc) and buy it the day before the day before you depart. Then you have a small buffer in the front in the unlikely event that you have a problem purchasing. I'm not sure if you've bought add-ons before or not, but they can be a bit confusing as there's an unintuitive 2-step process required. If you'd like a guide, please see here: https://productioncommunity.publicmobile.ca/t5/Plans-Add-Ons/HOWTO-Purchasing-Add-ons/m-p/198974#M22...
02-05-2019 10:21 PM
02-05-2019 10:14 PM
If travelling to the US, is it best to purchase the add-on from the Canadian departure airport prior to boarding for the US flight? Or, can you purchase it upon arriving in the US?
thank you,
mj23
02-05-2019 07:37 PM
@GreatCanadian wrote:And yes you can stack your add-ons.
GC
Only the US Roaming Data add-ons. Do not ry to purchase more than 1 each of the US Roaming Talk and US Roaming Texting add-ons at a time or they will stop working.
02-05-2019 07:09 PM
@popping is right about the plan starting immediately on purchase. And the day you purchase it is Day 1. So if you purchase at breakfast or after supper Day one ends at midnight (eastern time I think). It's not 24 hours.
GC
02-05-2019 07:03 PM
@BoboDultmica wrote:What carrier do you switch to while in the US, and can you bundle the $20 talk, text and data plan with the 1GB data plan?
It depends on your US locaton?
You will get AT&T or T-Mobile.
Enable roaming and restart your phone when you arrive at USA to connection to any one of these network.
Please note that US roaming add-on starts right away for 10 days.
02-05-2019 06:59 PM
GC
02-05-2019 06:58 PM - edited 02-05-2019 07:01 PM
AT&T and T~Mobile, are the networks PM will use.
Edited to add: There is no bundle plan with 1GB of data so you would need 2 different plans if you are looking for that much data
