yesterday
yesterday
hi @Nigels
check the Usage breakdown, it should be there
Login My Account or PM app, click Usage Breakdown under the usage meter and it will expand and you will see it there
if you still do not see them, ask PM agent to help
submit a ticket with CS Agent using Chatbot here:
Type the question "Ticket", Then click the following in order: "Account Management" , "Log In".
(If unable to receive 2FA SMS, click "Didn't Receive Code" or "Resend Code" and Select "Send Email")
If any issue with ticket submission, you can submit ticket by direct message:
