US add on
trtlmn
Hey there.  So I’m traveling to the USA this winter.  How do I get US roaming, text and calls? Can I get add ons?
2 REPLIES 2
cavemantoronto
The new plan talked about above is $60 for calling canada-wide and us-wide, text messaging, 8.5GB in Canada, and 2GB in the U.S.  This can be a good deal if tou visit U.S. regularly.
kselmak
You can purchase add-ons from your self serve page.
First you'll load your account with the funds them you can buy them
Best bet is to get them before you leave
Another option is to go for that new plan, all depends how long you are staying and what is the difference you'll be paying. If you will be there for 2 weeks or more or you if you are already on 40 or 50 plan depends on the adon it may make sense just to switch (assuming it's still available) you'll be able to schedule switch back for the next cycle right after first switch.
Safe trip:)
