US Roaming
Jonnigun
Purchased US Roaming for talk and text and did not work the whole time I was in US
2 REPLIES 2
will13am
@Jonnigun , were you at least able to connect to a roaming partner network?  Talk can be a bit iffy due to 3G network shutdown.  Text should be fine as long as there is a network connection.  MMS will require roaming data to be enabled even if roaming data was not purchased.
dabr
@Jonnigun   You can request an account credit from customer support via chatbot or CS_Agent.  Try the chatbot first.
chatbot:  https://widget.telus.tiia.ai/publicmobile/publicmobile.html
CS_Agent:  https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
