05-24-2026 10:26 PM
Does the $35/75 GB plan for use within Canada, US and mexico include full roaming in the US. Thanks.
05-24-2026 11:21 PM
Thank you.
05-24-2026 10:55 PM
yes it does. Just make sure to enabled Roaming in settings. Ignore the sms you get Welcome to USA..with a nag to buy add-on mins. You have all you need for use while in USA and Mx.
