US Roaming
Maginn
I purchased a US phone and text roaming. The text works but the phone does not.
@Maginn  Tap the down arrow by time stamp in your post you want to edit
Maginn
How do I edit my post?
@Maginn  First edit out your number this is public forum . But make sure your phone set to 4G/LTE and connect to T mobile or AT&T if still issues with voice try phone set to 2G and connect only to T mobile . If you have data option in your roaming package ensure data roaming is turned on in phone settings
HI @Maginn
please remove your phone number as you are posting it for everyone
for the roaming, you cannot make calls? try to change to T-Mobile and connect manually.  If your network mode has 2G , change to 2G or leave it as Automatic if you don't see 2G as a choice
