US Roaming Not Working
Abdullah14
Hi,
I am in Dallas right now and my US data roaming package is not working. I’ve went through an insured that my data roaming, cellular data, APN settings are all configured. Can someone please help me because this is frustrating. It shouldn’t be this hard to utilize an add-on, and it’s frustrating that I’m trying to figure this out without any data in the US. Much appreciate your help.
@Abdullah14
You’re welcome, we are here to help but enable VoLTE for voice calling.
Abdullah14
Cellular data was enabled. However, the automatic Selection of AT&T was the issue. I had to go and turn auto select off and select AT&T manually. Thanks for your help
@Abdullah14
It should work but also enable VoLTE in the Voice & Data settings.
I have the iPhone 14 Pro Max but I use the TextNow SIM while in the USA.
Abdullah14
I have an iPhone 15 Pro, connected to AT&T with 5G Auto. Thanks.
@Abdullah14
Make sure Cellular Data Roaming is enabled and manually connect to the T-Mobile or AT&T network in the Network Selection settings.
Phil_Adelphus
@Abdullah14   Are you connecting to either T-Mobile or AT&T with your phone set to 4G/LTE?   What phone do you have?
