04-03-2023 10:45 PM
Is the 15 day package for US roaming going to be the standard going forward?
Also, will my phone have to be VoLTE enabled for for talk, text, and data or is is VoLTE required only for talk?
If anyone has a POCO X4 Pro 5G, do you know if it's capable of running VoLTE? I don't see the option under Mobile settings.
Add-Ons
04-03-2023 11:37 PM
self solution removed
04-03-2023 11:23 PM
I found out how to turn on VoLTE. If anyone else has a POCO X4 PRO great instructions were provided here.
04-03-2023 11:18 PM
@Dunkman wrote:US roaming use to be only 10 days. Now it is 15 days. Don't know if Public mobile will change going forward.
VoLTE will give you better talk quality. If not, you will still be able to use T mobile 2G network for talk (unreliable and spotty coverage in US). Data and text will not be affected by VoLTE.
It looks like POCO X4 Prog 5G is VoLTE enabled (from quick google search), but it is not on the list of phones that Public mobile listed.
https://www.publicmobile.ca/en/ab/get-help/articles/volte
However, several customers have been able to use PM VoLte on their phones that are not on this list.
Telus has always been very picky at allowing devices that weren't purchased through Telus to be used for VoLTE. While a device may be VoLTE capable, I wouldn't count on it being usable on Public Mobile VoLTE unless the device was purchased through Telus/Kooodo/Public.
04-03-2023 10:54 PM
