US Roaming Add On - Sending SMS Messages
Derrick_W
Hi,
Maybe this is a dumb question, but I just want to send and receive SMS messages for a few days while I'm visiting New York City. So if I buy the "US Roaming - 250 MB Data" Add-on, would that include sending SMS messages?
Or do I have to buy the "US Roaming - Talk Text" Add-on instead?
Derrick_W
Right, got it - thanks for the info!
Derrick_W
Ah ok, thanks for letting me know, appreciate it!
HI @Derrick_W
if it is SMS text , you will need the US roaming -Talk Text
if you want to receive iMessage, you will need to have the data roaming.  But if you send a lot of pictures, 250 can be used quickly
TheSterlinger
You’d have to purchase the US Roaming - Talk Text add-on. The data add is just for data.
