US Roaming Add-On Not Working
03-08-2019 03:23 PM - edited 01-05-2022 03:38 AM
03-08-2019 05:11 PM
@BGL a écrit :Thanks, popping. I tried it but it did not work.
The only solution is to answer the moderator... and wait.,, they will fix your add-on.
03-08-2019 04:50 PM
03-08-2019 04:47 PM
We really want to help you. Please, kindly contact us through the online community as it's a better place to get assistance with any of your inquiries: https://bit.ly/2CDoc2k.
Regards,
Public Mobile Moderator Team.
03-08-2019 03:26 PM
@BGL wrote:I had the talk-only US roaming add on for 10 days (ended midnight last night) and it worked perfectly. An hour ago, I purchased it again, but this time it isn't working. I tried restarting my phone, switching from AT&T to T-Mobile -- nothing works! Can you help?
Your account may not provisioned correctly. Try the lost/stolen phone trick to re-provision your roaming feature.
1. Login to your self-serve account.
2. Report your phone lost/stolen using [Plan and Add-Ons] --> [Lost/Stolen Phone]
3. Logoff
4. Wait 5 minutes and login again
5. Report your phone found.
6. Re-start you phone to provision your account again. i.e. enable all features of you plan again.
