US Long Distance
06-14-2023 08:45 AM
I have both US and international long distance add-ons. Why are my US calls being charged against international long distance?
Add-Ons
06-14-2023 11:42 AM
I can't really complain if they use the freebies up first. Once I start paying for add-ons, if it doesn't work the way it should than I will complain. But I have lots of free minutes to use up first.
06-14-2023 10:41 AM
Maybe other keen observers can verify my theory that maybe the system uses up the freebies before moving on to any paid add-ons. Like maybe with data. Or maybe the other way around. I just wonder if the system looks at paid or free and decides which one to use.
I do think that if one has a particular add-on that has the same destination as another that it should use the particular add-on. But I don't operate this cell service 🙂
06-14-2023 09:47 AM
@Nomi Support has done the right thing 🙂
06-14-2023 09:46 AM - edited 06-14-2023 09:47 AM
@Nomi Sweet and I agree with you 100%
06-14-2023 09:45 AM
They have refunded the cost of my US minutes to my account, so my next renewal will be cheaper. As long as they are freebie minutes I can't really complain about using them first.
06-14-2023 09:43 AM
@Nomi possible support can fix it. But look like this is how the system is coded, so, if you really need to make it right, you have to fix with support all the time
So, at the moment, the US LD addon is untouched (because system is using the bonus add-on)? If so, maybe ask support to reverse the US LD addon transaction completely instead, since it won't be used at the moment
06-14-2023 09:42 AM
They say that they are charged in order, but not exactly. I have 4 different holiday/bonus giveaways, but they are currently charging to the second oldest. Whatever; when my freebies are done I will add a US add-on and later an international one. If they don't charge correctly then I will worry about it.
06-14-2023 09:40 AM - edited 06-14-2023 09:40 AM
@Nomi Good plan , use up freebies first . So many mysteries around here .hard to keep up with them all 🙂
06-14-2023 09:37 AM
Yes, I have only had the freebies until now. It has been taking from the second oldest. But it looks like I have to use up all the international freebies before I add the US one. It will be a while yet.
06-14-2023 09:35 AM
@Nomi wrote:Yes, but I also make international calls. I bought cheaper US minutes to use to call there instead of wasting my international minutes. (Up until recently I had US calling included in my plan, so this was never an issue.)
@Nomi are they taking the minutes off from the Bonus International minutes addon you got in December?
The order where the minutes are charged is confusing. Open a ticket with PM support and see what they can do. Sometimes, they can add back the minutes on the wrong add-ons they charged from. Message them:
06-14-2023 09:34 AM
@Nomi Well that not what happened in my case because I’ve never bought a add on just the free holiday give aways and as you see in my screen shot they took from two one was a year older then the last
06-14-2023 09:31 AM
I have been told that this is supposed to be done in the order the add-ons were added. If you have international add-ons that are older than US add-ons, they will use the international ones. When my freebie international minutes are used up, I will buy a US add-on before an international one, which should charge the US calls to the US add-on, and the non-US calls to the international add-on.
06-14-2023 08:54 AM
06-14-2023 08:51 AM
06-14-2023 08:47 AM
@Nomi I’ve wondered this my self , it’s just takes from what ever available it seems
check data plan / mins / add ons
