US Data Roaming not working
jblanchet
@CS_Agent Hello, twice now I've purchased the $10 200MB US data roaming and have been unsuccessful with it. Maybe I'm doing something wrong:
- I purchase the add on (not just add money to my wallet)
- Confirm that it's listed in my add ons
- Once I'm in the states I turn on Data Roaming and connect to AT&T
- I try to use anything with data and have no luck
When I check back on my account it says I used 0/200MB.
This is all done on an Android Nexus 5X. When I look at my cell network icon, it says LTE but has the small x in the corner.
Thanks
1 REPLY 1
CS_Agent
Customer Support Agent
Thanks for reaching out to us @jblanchet
Sorry to hear that you're unable to use your US roaming add on. I've just sent you a private message 🙂
Best,
Syed
