US Data Roaming Addon
TimTim
Hi can someone explain the us roaming add on for me?
1. under the section it says "for 10 days only" however when u look at the options it says 15 days in brackets so which one is it?
2. Also does it activate right away? For example I need it on the 25th so I should buy it on the 24th?
1 REPLY 1
HI@TimTim
1. it is now 15 days (they changed from 10 to 15 last month)
2. it will kicks in IMMEDIATELY after purchase is successfully done.  So, better to leave it till you use or just buy it shortly before your trip
