US Addons
rtylerpaul
I'm going to the US and wondering if it will work if I pay for a voice only addon and then a 1 GB data only addon to give me voice and 1GB data or am I forced to go with the 20$ plan for 250mb data voice text?
rtylerpaul
Thanks that's perfect
will13am
@rtylerpaul , you can buy multiple roaming add-ons, just can't purchase the same one twice.  The add-on starts immediately which is why buying the same one twice is not allowed.  Once an add-on is expired, you can repurchase it.
GinYVR
@rtylerpaulYou need a base canadian plan (minimum $15) before you can have a working US roaming add on.
