03-29-2022
09:09 AM
04-01-2022
03:47 AM
computergeek541
I have data I can call and text and I checked I have like 800mb left but when I try and use my data it just says “cannot activate cellular data network” can someone help me with this asap
03-31-2022 08:24 PM
@maxwello11 try you SIM card into another compatible phone to see if data works. This will rule out a device issue.
Check your apn settings on your device: https://www.publicmobile.ca/en/on/get-help/articles?q=apn
Perform a Reset of your device's Network Settings.
This also resets Wi-Fi networks and passwords, cellular settings, and VPN and APN settings that you've used before.
Iphone:
To Reset Network Settings, begin by opening the Settings app. Next, tap General -> Transfer or Reset iPhone -> Reset -> Reset Network Settings. and enter your passcode.
Your iPhone will reset network settings and restart itself.
android:
Find and tap Settings > System > Advanced > Reset options > Reset network settings.
If issues persist, submit a ticket to CSA for assistance.
To contact the Public Mobile Customer Support Agent (CSA)_Team, there are two methods to reach them found here:
03-29-2022 09:17 AM
@maxwello11 are you using Android or iPhone?
if Android, please confirm you do not have a data limit setup for Mobile Data. PM is running on 30 days schedule but phone cycle is running on monthly, so, the setting could cause issue
03-29-2022 09:16 AM
@maxwello11 , have you tried some of the techniques listed in this site?
https://appletoolbox.com/iphone-could-not-activate-cellular-data-network-fix/
03-29-2022 09:15 AM
It’s on, I’ve turned it on and off, restarted my phone, reset data settings, cleared data statistics still nothing. Incoming calls and texts are working yes
03-29-2022 09:13 AM
@maxwello11 do you know if you incoming calls and texts are both working too? Please try and confirm
for your data issue, make sure you have mobile data turned on. The error looks like the mobile data is disabled on the device setting
