07-25-2020 09:54 AM - edited 01-05-2022 12:15 PM
I've checked the models supported & unfortunately, the one I'm interested in doesn't appear in the drop down list.
I'm really hoping that the drop down list isn't up to date.
Can someone please comment if it is & if so, why the UMIDIGI A7 Pro doesn't qualify? Is there any chance that it will qualify any time soon?
Thank you.
Joining Public
01-08-2021 07:56 PM
11-19-2020 07:09 AM
07-28-2020 05:07 PM
The Umidigi A7 Pro works perfectly with Public Mobile. Just received mine and everythhing works as expected, hope this answers your question.
07-25-2020 05:56 PM
Thanks so much. o/
07-25-2020 05:48 PM - edited 07-25-2020 05:49 PM
@PatB Not a problem. Just have the Public Mobile APN settings handy because your going to have to enter them manually to get the data up and running.
07-25-2020 05:45 PM
Thanks so much. Once I receive the phone, I'm pretty sure to be back here. 🙂
07-25-2020 12:01 PM
@PatB All Umidigi phones are compatible with Public Mobile. All Umidigi models are Global models and support most world bands so nothing to worry about.
07-25-2020 10:21 AM
@PatB if you haven't already activated. Here's 4 articles on activation and porting and the Refer a friend reward if you need them:
1. What you require to activate https://www.publicmobile.ca/en/bc/get-help/articles/what-you-need-to-activate
2.How to activate https://www.publicmobile.ca/en/bc/get-help/articles/activation-account-set-up
3.How to port https://www.publicmobile.ca/en/bc/get-help/articles/choose-your-phone-number
4. Refer a friend https://www.publicmobile.ca/en/on/get-help/articles/the-refer-a-friend-reward
Please note your previous providers account must be active to port your number. The port will close it once its completed. Welcome to the community. Stay safe.
07-25-2020 10:19 AM
I saw this as well & while I didn't see the model in the list, I felt it must be supported. Really appreciate the confirmation though. Thank you. o/
07-25-2020 10:18 AM
Thank you. o/
07-25-2020 10:11 AM
07-25-2020 10:01 AM - edited 07-25-2020 10:17 AM
@PatB its supported. I'm currently waiting for one to arrive from Aliexpress. It has 3g bands 3 edit 2 and 5 and 4g band 4 plus more. Stay safe.
Supported network bands
[4GB+128GB version]
4G: FDD-LTE: B1 /2 /3 /4 /5 /7 /8 /12 /13 /17 /18 /19 /20 /26 /28A /28B /B66
TDD-LTE: B34 /38 /39 /40 /41
3G: WCDMA: B1 /2 /4 /5 /6 /8 /19
TD-SCDMA: B34 /39
CDMA EVDO: BC0 /BC1
2G: GSM: B2 /B3 /B5 /B8
CDMA1X: BC0 /BC1
[4GB+64GB version]
TD-SCDMA: B34 /39
Stay safe.
07-25-2020 09:56 AM
The compatibility list will never be fully up-to-date. Ensure that the phone has UMTS 850 and 1900MHz.
