01-08-2020 12:35 PM - edited 01-05-2022 08:56 AM
I am down in the U.S. for 60 days. The first 10 days of my $20 add-on just finished. I tried to go on the Public Mobile website to add another 10 days but it doesn't show up as an add-on. I have sufficient funds in my account. Why should I have to spend $25 to get add-ons that give me what I had been getting for $20 ?
01-08-2020 01:06 PM - edited 01-08-2020 01:06 PM
@saratogabill For trips to the US longer than 10 days the current PM US roaming addons are not worth the IMO hassle. I agree with you best to explore local prepaid options.
01-08-2020 01:01 PM
@saratogabill wrote:This is B.S. I'm going to switch to the cheapest Public Mobile plan just to keep my phone number and then get an AT&T sim card while I'm down here. I'll end up saving money !!
For the amount of time you're going to be in US...good idea to get a local sim and a cheap plan. Alternative is to get a free voip app like TextNow. Works good for free calls and texts as long as you have a robust wifi signal. I'm sure there's others but I've used TextNow with good results.
01-08-2020 01:00 PM
Or you can suspend your service up to 90 days and buy AT&T to save even more![]()
01-08-2020 12:55 PM
01-08-2020 12:38 PM - edited 01-08-2020 12:41 PM
@saratogabill wrote:I am down in the U.S. for 60 days. The first 10 days of my $20 add-on just finished. I tried to go on the Public Mobile website to add another 10 days but it doesn't show up as an add-on. I have sufficient funds in my account. Why should I have to spend $25 to get add-ons that give me what I had been getting for $20 ?
If you can wait for 24 hours after the first one expired...then you can renew. Alternative is to click the ? in lower right side to start process of moderator assistance. make sure you have enough $$ in Available Funds to cover the add-on you want.
