Two phone numbers?
Mjack66
Hello,
I recently signed up for monthly prepay with Public Mobile and was given a new phone number and SIM card (825 area code) and was told I could sign in and change it to another number. I did this the same day.
It has now been almost two weeks since then and people are still receiving texts and calls from the 825 number but when they call my new number my phone rings.
My account on Public mobile says this new number as well and I got confirmation that it had changed. So I have no idea which is my true number. I thought that this switch would  take 24 hours to clear up, but no such luck.
Any advice would be very helpful!
Thank you!!
This shouldn't even be possible.  Clearly, the problem is on Public Mobile's side. The moderators should be able to fix this for you fairly quick.
Mjack66
Thank you!
hairbag1
You'll have to click the ? in lower right of screen to start process of moderator assistance.
sunflowershine
@Mjack66 You need to talk to the Moderators to work on this issue. You can simply click on the "Question Mark" down at the right hand corner and get a ticket.
