Two numbers beside User ID?
Meow
What these 2 numbers beside user ID (19  19) at right hand side mean ?
 @himamx : If you mean your own Public Mobile phone number then you can do that in your self-serve account using the Change Phone Number function.
Be aware that your taxes might be different coming from a different province.
If you mean porting in a Canadian number from another provider then you can do that during activation and also in the self-serve in the same place.
If you mean some kind of foreign number then you can't.
@himamx You can change your phone number up to 4 times every 30 days after you’ve activated. To change or transfer your number after activation, go to your Self Serve Account here and:
  • Select the “Plans and Add ons” tab
  • Click on “Change Phone Number”
  • Then, you can choose to select a new phone number
himamx
hello, i would like to know how can i change long distance number to ontario number
 @Meow : Have a look with a mobile browser. The right one is current time online. The other is a bed. Inactive but logged on?
