Turbo hubs
Gordonpower279
Does anyone know if a data only package will work with a zte turbo hub?  Thanks
2 REPLIES 2
NDesai
I heard from others before that PM sim do not work on LTE router or hubs. If you already have it, i would give it a try if you want it badly. Otherwise, explore other options.
mimmo
No personal experience, are you able to set apn in it?
Do you have a current pm sim with day that you can test?
Personally i would check out fido's or koodos data only tablet plans.
