11-01-2016 04:31 PM - edited 01-04-2022 04:11 PM
11-01-2016 05:18 PM
Perfect. Yeah it just seems like it got frozen on that screen. You are good to go now.
Enjoy public mobile 🙂
11-01-2016 04:57 PM
Thanks for the reply. It's still stuck on that screen, but it seems to have activated anyway. The phone works and I got a confirmation text from Public Mobile with my pin.
11-01-2016 04:49 PM - edited 11-01-2016 04:50 PM
Mine took about 15 minutes. Just be patient as alot of these are going through at once. It will finish. When it finishes you will be able to login. So open another window and see if you can login. If yes then its just frozen on that screen and your good to go.
