Trying to get an agent to Help
NinaCameron01
Hi
My data isn't working but my phone line is. When I go out I can make and receive calls but I can't use the internet. I've been trying to message an agent to get help but it doesn't seem to be working. Can someone message me please?
Thanks
NinaCameron01
I think you are correct
It is an LG
dust2dust
Sounds like an APN issue. What make and model is the phone?
hi @NinaCameron01
the phone was never used or Pm  network?
try to Reset All Networks and see if it works
if iPhone, update the Carrier Profile
JRod
@NinaCameron01
Can you double check in the settings of your phone that your data is enabled?
Also it would be worth signing onto your account and double checking on the overview page how much data you have used this month. You can hit the reverse clock logo to refresh the info to get the most up to date usage:
If it’s showing that you have data remaining and your phone does indeed have data enabled, please reach out to customer service.
Please click this link below to message customer service:
Keep an eye on your mailbox here as that is where your reply will come in (envelope icon on desktop, click your avatar icon in the corner and then click messages if on mobile).
