05-10-2024 01:17 PM
I see that there are 5 registered trusted devices in my account.
Can I add more trusted devices to login to my account without login in everytime?
I have my desktop, 3 iPhones and 3 Samsung phones I want to register 2 more devices as Trusted Devices.
05-12-2024 11:54 AM
Yes, you are quite correct and thank you!
Trusted devices are there... I rarely use app so was not aware of that info there. Prefer bigger screen of laptop 😁
05-10-2024 06:14 PM
It is in my app under Accounts>Manage Login (Secure by Eversafe) and there is a listed of trusted device and the last it was login to my account.
I’ve noticed that the 5 trusted devices had no issues in login but when I login with the 6th device. I had to use the 2FA code to login. Not a big deal but the other 5 device I am login automatically.
05-10-2024 01:36 PM
Trusted devices are added automatically as trusted, when you login from a new device.
But you can't add them from the "Trusted Devices" page.
Sending the 2FA code to email is an option, if it's any easier for you.
05-10-2024 01:23 PM
Where do you see that number of 'trusted devices'? I went through my account but did not see it anywhere.
05-10-2024 01:20 PM
HI @BKNS27
i don't think there is a limit to the number of trusted device. But I think the option might not work 100%. it might be related with your browser. Some people use browser that does not save cookie and that will break the truest function
