Troubles with voicemail
Leejoydur
I've never been able to access my voicemail
@Leejoydur ,
Find which voicemail access number is in your area, and save it as your Voicemail phone number:
https://productioncommunity.publicmobile.ca/t5/Using-Your-Service/Updated-list-of-Voicemail-Access-N...
 @Leejoydur : What happens when you press and hold the 1 key in your dialer?
Try dialing 17785804001 to see if you have a voicemail box. If you do then you need to set up the 1 key to be able to access your voicemail.
HALIMACS
Is it set up, @Leejoydur ?
Here's how:
Set up Voicemail (publicmobile.ca)
