04-06-2020 09:30 PM - edited 01-05-2022 10:16 AM
I seem to be having trouble setting up a number...bought SIM card online, unlocked phone, and tried to transfer phone number from previous carrier (Virgin Mobile). However, the account on Virgin was closed before the porting process completed, so it failed to complete. Phoned Telus (Public Mobiles parent company), they recommended that I re-activate the Virgin account and try again. Phoned Virgin to re-activate, but they would have to send me a new SIM card. Decided to just switch to a new number instead. Phoned Telus again, and was walked through setting up a new number on the Public Mobile website. That didnt work though, because there was either a message displaying that “Phone Number change failed” or I would hit “Submit” and the loading circle beside the Submit button would spin for a while and then disappear as if it worked, but the website stayed the same and the Submit button was shaded. Phoned my wife with my contact information cleared to see what my number was, because at this point I wasn’t sure what it was anymore. The caller ID displayed a number from the USA...not sure what I can do at this point...
My Account
04-08-2020 03:55 AM
Hey, remember when phone numbers were 7 digits long unless you were calling long distance? Miss those days... looking at that link my area either has or is getting a 3rd area code... I already screen calls but that only makes it worse! lol
04-07-2020 10:19 PM
@Rindiraph wrote:Thanks yeah, turns out it's a Canadian number according to Google, but Call display thinks it's American. Oh well. Things seem to be working fine now
Thank you!
There isn't really anything that you can do about that. At some carriers (usually landlines) it's the receiving carrier that controls what the call display says for city/province/state/country. I know that sometimes when making calls to toll free numbers or receiving calls from a company that dsiplays a toll free number, it will sometimes say that it's a U.S. number when it's a Canadian number. On my cell phone, I tend to think that's a Google dialer thing.
04-07-2020 09:09 PM - edited 04-07-2020 09:11 PM
Side effect of Canada sharing the same "country code" - 1 - as the USA. Phones that don't have a specific name in their built in database for a new area code will revert to "USA" based on country code "1" ...
All all current and upcoming valid canadian area codes and prefixes can be found here though:
04-07-2020 08:22 PM
Thank you!
04-07-2020 01:09 AM
I believe that on order to port a number you have to do it while the account on old carrier is still in active status. If you are prepaid you want to start the process a few days before the plan expires in case of any delays so it will still be active for when/if you need a mods help
04-06-2020 11:47 PM - edited 04-06-2020 11:57 PM
Without searching...iirc, that number isn't really American. I suspect it's a new area code and prefix that hasn't made it to all the lists.
Google your area code and prefix and see where it gets you. Check various sites.
Edit: @Rindiraph : the phone that says it's a us number...is it with Rogers?
04-06-2020 11:46 PM
@Rindiraph wrote:Yes, it looks like my number changed from my previous number that I had with Virgin Mobile to this American number. The time looks roughly the same as when the porting request was cancelled. Also tested my incoming call capabilities, and everything seems to be working now. Just wondering now if having an American number is going to be an issue as far as fees for myself or others
What is the area code? I am surprised you have an American number with PM.
04-06-2020 11:28 PM
04-06-2020 09:33 PM - edited 04-06-2020 09:35 PM
@Rindiraph was your credit card charged? Thanks. If it was, try logging into your self service account. Use this link here https://selfserve.publicmobile.ca . You will see your number in there.
