11-01-2019 09:07 AM - edited 01-05-2022 07:48 AM
I am planning to travel to the Dominican in January, can I still use my phone there? I know text won't work but will I be able to use wifi for email etc?
Joining Public
11-05-2019 04:11 PM
@Dunkman wrote:
@RC25 wrote:I realise their is no roaming in DR but wondering if I can still use wifi for email etc
Yes, you can still use Wifi if there is a Wifi connection near you (ie. hotel).
@RC25 WiFi has nothing to do with your mobile data provider. If there's a hotspot, you can use it form any device with a WiFi radio, including your phone(s).
11-05-2019 03:14 PM
@Kim1971kim wrote:Take your SIM card out just in case or turn data off and yes you can still use wifi 🙂
Public Mobile doesn't work in the Dominican Republic nor would Public Mobile charge even it did work. The only reason to remove the Public Mobole sim would be to insert a different carrier's sim that does work there.
11-05-2019 11:02 AM
11-01-2019 09:40 AM
11-01-2019 09:37 AM
11-01-2019 09:31 AM
Standard Public Mobile plans only cover Canada. International Add-Ons only cover the United States and the British Virgin Islands
Here is a link to the Public Mobile coverage map: https://www.publicmobile.ca/en/on/coverage
You can change the country on the coverage map from Canada, to US, to other countries to see where the US and international add-ons cover.
Here’s a link for information on the Add-Ons:
https://www.publicmobile.ca/en/on/get-help/articles/travelling-outside-of-canada-and-the-us
11-01-2019 09:21 AM
PM only offers roaming in the US. You could purchase a sim like Gigsky or use wi-fi apps like TextNow, Whatsapp, or Skype.
11-01-2019 09:13 AM
@RC25Your phone service will not work there but your wifi should work as long as you find a wifi spot that allows you to access it.
