Travelling
JB0310
I am going out of the country this summer - to Ireland and other places in Europe.
Does Public Mobile have a good plan for this? have other found it's worth getting?
DennyCrane
Check out travel e-sim options from Ubigi or Airalo. You can set it all up ahead of time, and then just turn on the e-sim when you arrive. Of course you'll need an e-sim capable device. Also note these are just data plans, no calling or text. If you need that you'll probably want to look at purchasing sim cards locally.
@JB0310
PM only have roaming service in USA.
You will need to purchase a local SIM in Ireland but you can use WhatsApp or TextNow app for free calling and texting when connected to wifi.
@JB0310  No sorry PM only has roaming in the US . Best to get local pre laid SIM card in Ireland. For your trip
