01-27-2026
05:05 PM
01-27-2026
05:12 PM
computergeek541
Hi team
I have trouble transferring number from Fizz. When I use the Transfer number button, it said that the number is not Eligible. Thus, I'm using Mobile plan now from Fizz, but Text and Call are still from Fizz.
01-27-2026 05:09 PM
hi @PhucLe
if you already requested porting when you subscribed, you don't need to go to Profile and click 'Transfer number" button again.
Did you get a text from the old carrier, did you reply Yes within 90 mins?
and can you receive inbound phone calls, especially from Non-Telus/Koodo/PM phone? If you cannot the port was not done
It could be an incomplete port. PM porting support team can help. I have sent you the porting support team number. Please check your Community inbox (https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage), check for the number and call.
And in case the poring team cannot help and ask you to submit ticket (or you rather submit ticket anyway), you can submit ticket by direct message:
