4 weeks ago
I have an account under a different email and phone number that will not let me login despite resetting the password multiple times. I reset the password, attempt to login with the new password, and it does not work. I need to update my credit card info on the account.
4 weeks ago
were you using PM app? on some phone when you use PM app to enter the password, the keyboard will change the first character to Capital and hence the password is wrong. If you have been using PM app, click the eye to check the password before submitting to login
or you can try using browser with Incognito mode
but if that does not help, ask PM to help to sort it out
Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here:
